Separate Up Next/Continue Watching list than Emby
Hey folks,
Is there any way to make it so that Infuse does NOT pull the Up Next/Continue Watching list from my Emby instance and rather has a separate list which only lists the media I watch using the Infuse app?
If not, can this be added?
TIA
Don’t use direct connection with your emby server, use the Library mode of Infuse. I believe that will give you the up next/watching from Infuse.
Thanks for the reply! Just tried this based on your suggestion, I still see up next/watching from Emby. Interestingly, I only synced my movie library but Infuse still gives me the option to Continue Watching TV Shows, which it cant even access.
Update - If I play a TV Show from continue watching, it will play it, even though I did not sync the TV Library at all. Is this normal behavior?
Any solutions?
