Separate library folders
So you can link your plex up in Infuse which is great however it just shows up as the server you choose on home screen whereas I want it as the separate library folders. Is that possible?
I know you can do it if you link up a google drive and then favourite the folders you’d like to show up in the home screen and index that way but not sure how practical that would be.
Any help would be appreciated.
Anyone?
Sure, you can do the same thing with Plex.
Simply browse your Plex share via Settings > Shares > Plex Server Name. Locate the items you want to see on the home screen, and add them as Favorites.
