It would be a very usefull feature to be able to select which database (thetvdb.org or themoviedb.org) use when searching metadata for a movie\TV show.
I experienced a problem with a TV show because the app was looking into the movies database (the filename was in the xxxx_yzz.ext format, where xxx is the name of the show, y the season and zz the episode) and there was no way to forse a lookup on the tv series database.
It seems that renaming the file as xxx_sy_ezz.ext fixed the problem (the app searched metadata in the proper database).
This is something we’re hoping to improve for a future version.
In fact, we’ll likely be switching to TMDb for TV show data as well in the near future.
