I am having an issue where with many 1080p mkvs when I try and seek to a certain location it takes about 30secs and it will have only advanced a few minutes.
My setup up is a windows server machine with a raid on it.
SMBs shares and I’m running off the share.
Everything is hardwired
Are you drives perhaps being put into sleep mode? What setting do you have for cache? Did you try a speed test through the app? You can try changing the SMB version and see if that makes any difference.
