Seasons in wrong order
Has anyone else had this issue? For some reason the seasons for my TV shows always have the oldest season at the end so like 2, 3, 4, 5, 1. I’ve attached a few pictures to better show what I mean. Any ideas why it’s happening?
Thanks.
Does this happen on Infuse in tvOS also?
The only time I ever see this happening is when the naming convention in the filenames is different in that one season than the rest of the seasons.
For example, even dots (.) can cause this.
Let’s say you have Doctor Who season one filenames without dots like so:
Doctor Who S01E01 episode name.mkv
Doctor Who S01E02 episode name.mkv
Doctor Who S01E03 episode name.mkv
and so on…
But then all other seasons with dots (.) added in the filenames like so:
Doctor.Who.S02E01.episode.name.mkv
Doctor.Who.S02E02.episode.name.mkv
Doctor.Who.S02E03.episode.name.mkv
and so on…
Doctor.Who.S03E01.episode.name.mkv
Doctor.Who.S03E02.episode.name.mkv
Doctor.Who.S03E03.episode.name.mkv
and so on…
This can cause that issue to happen.
Might be worth checking that first to see if the filenames in those oddly ordered season numbers are different to the other seasons.
Let me know.
Hi, yes also happens on tvOS
that’s a possibility, I will check and get back. Thanks for that. Odd bug if it is the case.
@yatesfox it would appear you’re right with the naming convention. Annoyingly seasons 9, 10, 11 have been named Doctor Who (2005).S09.E01 and season 7 Doctor Who (2005) S07.E01 so the full stop between the ) and S is whats causing the season to be put out of order. I wonder if this is something infuse can look into. Wont take long to correct but is a pain. Will be more careful in the future. thanks ofr your help guys.
You’re ordering your libraries by date added instead of title. Done. Go to your settings and change this.
No I’m not. If that were the case they would still be in the correct order or reverse order depending on whether the newest or oldest added was set to be shown first. I resolved the issue. It was the naming causing the issue as explained above. Changed it and now all showing perfect.
Alright–glad you resolved it. It should be noted that Date Added does not guarantee the reverse order for seasons. I have plenty of shows where the seasons are unordered because they were not added chronologically, but sorting by title sorts them from 1 to 10, for example.
