Seasonpass wont open
instantly get error message:
The application failed to initialize properly (0xc0000135). Click on ok to terminatethe application.
thoughts?
thanks jim
Windows will give you this error if you try to run any application that requires the “.NET Framework” to run, but your computer does not have “.NET Framework” installed. To fix it, just install the .NET Framework from Microsoft:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=333325fd-ae52-4e35-b531-508d977d32a6
