Can someone please help me!! i keep downloading season pass and it is the tehtered boot!! My PC is updated and ive gone through the whole jailbreaking process! How can I change to an untethered boot if I can't get the correct seasonpass downloaded? Please someone help!
[quote="kohana47"]
[/quote]
just choose the the untethered option - SP is the same
Please explain... The apple is already tethered. How do I change it to untethered? Would I have to re-jailbreak? I previously had sp with a exed out circle and now it is the tethered boot.
[quote="kohana47"]
[/quote]
please read read the tutorial on this site and view the you tube video. It is apparent that you have not.
I have done an untethered boot many times, but the new upgrade made it a tethered boot when I plugged it into tv. Instead of being rude, maybe you could be more helpful or just not respond at all. thanks
the SP download works on untethered. I have done several on this version.
you must provide information on what you are doing or nobody can help you. Software version, PC or Mac, etc. What steps did you do? Nobody on this site is telepathic, you have to provide info other than just asking for help.
Oh, you aren't telepathic?! As stated in FIRST post, from my PC. Jail broken through what I thought was an untethered boot. However, when plugged into tv, apple logo disappeares which is an indication of a tethered boot. I then booted it tethered, and it worked. My question is if I have already booted it tethered, do I need to restore it re-jail break it and then try the season pass untethered boot? Is this a support forum?
On the first boot after jailbreak it could tak up to 5 minutes for the ATV to finally boot, the apple logo does dissappear during that process.
5.3 is the latest untethered jailbreak. Seasonpass wont untether ANY jailbreak to untethered, you have to choose an untethered version of the ios. Without saved blobs, 5.3 is your only option. (see http://forum.firecore.com/topic/3418 for your options).
If you jailbroke to 5.3 (iOS 6.1.4 - 10B809) and it's still tethered then you are doing something wrong. If it gets too frustrating, I believe ATV flash black has an option in mainenence that will make 5.3 untethered.
[quote="kohana47"]
[/quote] WHAT FRIGGING SOFTWARE VERSION IS YOUR APPLE TV ON?? A simple question that you apparently can't answer!!!
Thank you Carpenter940! You have been very helpful!! And to the other douchebag, Jagrimey go fly a kite.. Being a nicer person will get you further In life. Peace be with you
[quote="kohana47"]
[/quote]
kohanahole, I ask you to post info regarding you setup to try and help. So take a flying leap and put your ATV up your koanahole.
Maybe you'll figure out that ur not on 5.3
Hey kohanahole,
posting info regarding firmware versions, etc. will help solve your ATV problem. Unfortunately, your ignorance for providing basic information regarding your setup does not help anyone Help you.
hopefully you'll figure it out before Apple quits signing 5.3. (HINT, HINT).
hasta la vista kohanahole
