Seas0nPass Win7 will not work
I will update my atv2 so latest version. I can go to DFU mode an all works fine, at the end the seas0nPass SW will hang.
I receive these logs:
DateTime: 31.05.2012 17:55:15 Message: Control named “aTV panel” found! Handle: (null)
DateTime: 31.05.2012 17:55:15 Message: Control named “aTV panel” found! Handle: Handle: 20730
DateTime: 31.05.2012 17:55:15 Message: Closing Modal Dialogs
DateTime: 31.05.2012 17:55:15 Message: Control named “Found modal dialog” found! Handle: (null)
DateTime: 31.05.2012 17:55:15 Message: Set iTunes to foreground
DateTime: 31.05.2012 17:55:15 Message: Apple TV panel found! Handle: 20730
DateTime: 31.05.2012 17:55:15 Message: Control named “Firmware restore button” found! Handle: Handle: 10774
DateTime: 31.05.2012 17:55:15 Message: Restore button found! Handle: 10774
DateTime: 31.05.2012 17:55:15 Message: Pressing Shift
DateTime: 31.05.2012 17:55:15 Message: Before Restore Click
DateTime: 31.05.2012 17:55:16 Message: Releasing Shift
DateTime: 31.05.2012 17:55:16 Message: Open File Dialog processing
DateTime: 31.05.2012 17:55:16 Message: Control named “Open File Dialog” found! Handle: Handle: 107B4
DateTime: 31.05.2012 17:55:16 Message: Control named “Path TextBox” found! Handle: Handle: 107C6
DateTime: 31.05.2012 17:55:16 Message: Path text box found
DateTime: 31.05.2012 17:55:16 Message: Path value set
DateTime: 31.05.2012 17:55:16 Message: Set dialog as ForegroundWindow and send enter to it
DateTime: 31.05.2012 17:55:16 Message: Work with confirmation dialog
DateTime: 31.05.2012 17:55:16 Message: Control named “Confirmation dialog” found! Handle: Handle: 2084A
DateTime: 31.05.2012 17:55:16 Message: clean up
DateTime: 31.05.2012 17:55:16 Message: After Restore Click
Exception occured
!!! Unhandled Exception caught in AppDomain.CurrentDomain.UnhandledException !!!
Exception occured
Itunes will restore the firmware, but without jailbreak. I don´t see the new settings.
Can you help me?
Thanks Scoty81
