I tried all of your suggestions. Nothing worked. Tried different downloads. All get stuck on “Unzipping”. Last error message I’ve got was “The firmware AppleTV2_1_4.3_8F305_Restore.ipsw is not compatible with this version of Seas0nPass”. Great. I can’t believe how stupid I was. I’m really tired of this. That’s useless.
Thanks for those of you who tried to help. No thanks for Firecore.
Hello I’m getting the same problem here… tried many ways to download to right ipsw but no luck… I’m willing to actually buy the atv flash . but … i’d like to see the jailbreaking works first …
Could I also please grab the link for the correct IPSW? I think I’m correct in saying that I can put the correct one in the My Documents/Seasonpass/Downloads folder and run the application again and it should work?
I just finished installing this. It took almost 5 hours of my life! I can PM you the link, download, put everything on the desktop, enter the “DUF” (DUF DFU, what ever) status as it says. I plugged in the AC, pulled it out after the light stopped blinking, plugged in the USB and then the 7 secs with the menu and play released and it worked. After that don’t do anything, let the program do it’s own.
Thanks Firecorist for the IPSW link! I don’t believe that the wrong file being downloaded is a problem with Apple’s servers after all this time. In any case, just replacing the dodgy one with the correct IPSW and then re-running SeasOnPass worked for me. ATV2 jailbroken in about 8 minutes (after three days of trying!). Now for the next challenge: XMBC. Wish me luck…
I’ve d/l the files from both sources over and over and they are both 303.5 MB and won’t mount. Can anyone please send me the correct file (or a link to it) so I can get this over with and start using my ATV@!
After playing around with XBMC it’s clear to see it’s a work in process. Not very stable with some shutdowns and very jumpy 1080P support, which means not watchable. Can any of the aTV Flash black people confirm of a better experience, with the FireCore software?
Thanks for the dropbox link it worked perfectly, however, no mater what I do I can’t get the ATV2 into DFU mode.
I’ve tried 2 different usb cables with no success. I’ve been plugging the power cord to the ATV2 then opening up iTunes on my Mac and then connecting the usb cable. The white light flashes quickly after 7 seconds of holding down the MENU & PLAY buttons and then flashes slowly a few times and then remains lit. The ATV2 has never shown up in iTunes (the way my iPhone does). Do I need to get a 3rd usb cable to try? How many different usb cables does one have to try?
I too am having the same exact issue never unzips. I can get a 289mb file or a 305.5 mb file. I understand them to be truncated, If you have a good DL link I would very much appreciate the help.
If you can connect to a US IP address and then click the link above, you should be able to download the correct filesize. From what I’ve read, this is now only affecting Europe.
P.S. I connected via VPN but a proxy might work too.
Well that would be all good but I’m in TX and the link doesnt work. Gives me a 289mb file. tried IPSW download and got a 305mb file, tried the i(whatever site mentioned above and it says it’s a 334mb file but only dl’s a 305mb file
Actually, sorry guys. I’ve just noticed the download I’m getting from a New York IP is only 289 MB, still, it’s about twice as large as what I’ve been getting in the UK.
[moderator edit - please don’t post non apple.com download links here]
Strangely, the RapidShare page lists the file as 334.24 MB but when downloading it’s registering as 319 MB. Once it’s finished downloading, it registers as 334.24 again.
IMPORTANT: You must change the file name to “AppleTV2,1_4.3_8F305_Restore” otherwise you will get an incompatibility error message.
Hey, I know weve all been having the same problem, Ive been looking for a proper 8F305 link for the last two days! If somebody could please help me out with the link I would be grateful thanks.
