I never had the search function return anything. What exactly is it supposed to search for/in? I have a few folders, INfuse indexes the content fine (i get posters, and metadata regarding the files) but then what? I thought that after the initial folder index, I could go to the search field to find something from the indexed folder. But that does not work. Even entering just a single letter does not return anything.
Please advice, its so time consuming scrolling through a folder with a lot of files.
thanks
Jakob
Infuse will return search results for any items that have been indexed in your library.
A bit more info on setting up your library can be found here.
Thanks. I had the shares mapped via Upnp and when I switched to smb the library started to update. Waiting for i to finish but it feels right. Thanks again
