SEARCH OPTION DOESN´T WORKS
Hi, I have the app PRO installed on APTV4 and Ipad 2 (ios 10.3.3) While on TVOS it works very well, on the Ipad, the “search” option does not work. What I can do?
Thank you
Search on iOS (and tvOS) will search through the items indexed into your Infuse library.
If you navigate to Settings > Library, do you have at least one Favorite selected there? How many movies/shows does it say are present in your Library?
