Search function not working correctly
Hi
When is Search fixed? Crew, Directors is still a big mess.
Kind regards.
Jens, Copenhagen.
Which version of Infuse are you using?
There were a few issues fixed in subsequent updates after 7.5 was released, and we’re not aware of any remaining issues.
If you are still having problems, you may try using the option to clear all metadata in Infuse and/or remove the app and redownload from the App Store.
