please help me with finding what gone wrong for my apple tv 2rd generation - it was left back at an at least 1 year old apple firmware - and i could see Things have changed and “had” to update my apple firmware and then I was assumming Sean0onPass could bring me back to jailbroken state… but I end up with this error(s) from Sean0onPass… please advice anybody… thanks in advance
I have the same issue. I am using ATV2 5.0.2 and itunes 11. I am trying to use seas0npass to bring me back to a fresh jailbreak, but get the same error message.
I have the same message. First, I let NitoTV do a complete update with as result an aTV2 stuck in boot loops. Next, I decided to re-jailbreak my aTV using a freshy downloaded Seasonpass.exe, but I get stuck with the same error as described above.
I am having the same issues, can’t seem to get past the critical error message. My ATV2 was working fine until I tried to an update and then it crapped out. After searching to find out what the problem was the suggestion was to re-jailbreak ATV2 and now this is where I am out with the critical error message. Any solution will be helpful.
I read another post that suggested it may be corrected by trying the jailbreak process on a fresh/other PC. I did that with 2 different laptops, one factory restored and both I got the same error.
