Hello Fellow Members
Device: Apple TV 2
Model: MC572C/A
Software Version: 5.0.2 (4250)
Is Apple no longer signing SHSH Blobs for 5.0.2?
I am using Tiny Umbrella 5.11.01 to Save SHSH Blobs and I get the following below
07/10/2012 23:03:13.264 You are using the current version of TinyUmbrella.
07/10/2012 23:03:13.273 Loaded History…
07/10/2012 23:03:13.406 Device connected: Apple TV
07/10/2012 23:03:13.440 Loaded History…
07/10/2012 23:06:03.021 Started saving SHSHs for [Apple TV]
07/10/2012 23:06:14.332 For version [AppleTV2 4.4.2 (9A336a)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.347 APPLE is NOT signing AppleTV2 4.4.2 (9A336a) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:14.394 For version [AppleTV2 4.4b5 (9A5302b)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.410 APPLE is NOT signing AppleTV2 4.4b5 (9A5302b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:14.581 For version [AppleTV2 4.1 (4.0) (8M89)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.581 APPLE is NOT signing AppleTV2 4.1 (4.0) (8M89) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:14.675 For version [AppleTV2 5.1b3 (9B5141a)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.675 APPLE is NOT signing AppleTV2 5.1b3 (9B5141a) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:14.815 For version [AppleTV2 4.4b1 (9A5220p)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.831 APPLE is NOT signing AppleTV2 4.4b1 (9A5220p) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:14.924 For version [AppleTV2 4.4.4 (9A406a)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:14.924 APPLE is NOT signing AppleTV2 4.4.4 (9A406a) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.049 For version [AppleTV2 4.3 (4.2.1) (8F202)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.065 APPLE is NOT signing AppleTV2 4.3 (4.2.1) (8F202) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.158 For version [AppleTV2 4.3.0 (8F455)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.174 APPLE is NOT signing AppleTV2 4.3.0 (8F455) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.268 For version [AppleTV2 4.4b3 (9A5259f)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.283 APPLE is NOT signing AppleTV2 4.4b3 (9A5259f) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.392 For version [AppleTV2 4.3b1 (8F5148c)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.408 APPLE is NOT signing AppleTV2 4.3b1 (8F5148c) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.502 For version [AppleTV2 4.3b3 (8F5166b)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.517 APPLE is NOT signing AppleTV2 4.3b3 (8F5166b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.626 For version [AppleTV2 4.2 (4.1) (8C150)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.642 APPLE is NOT signing AppleTV2 4.2 (4.1) (8C150) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.736 For version [AppleTV2 5.1.1 (9B206f)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.751 APPLE is NOT signing AppleTV2 5.1.1 (9B206f) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.860 For version [AppleTV2 5.1b2 (9B5127c)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:15.876 APPLE is NOT signing AppleTV2 5.1b2 (9B5127c) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:15.985 For version [AppleTV2 4.4.3 (9A405l)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.001 APPLE is NOT signing AppleTV2 4.4.3 (9A405l) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.094 For version [AppleTV2 4.4 (9A334)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.110 APPLE is NOT signing AppleTV2 4.4 (9A334) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.235 For version [AppleTV2 4.4b6 (9A5313e)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.250 APPLE is NOT signing AppleTV2 4.4b6 (9A5313e) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.328 For version [AppleTV2 4.4b4 (9A5288d)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.360 APPLE is NOT signing AppleTV2 4.4b4 (9A5288d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.453 For version [AppleTV2 4.4b2 (9A5248d)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.469 APPLE is NOT signing AppleTV2 4.4b2 (9A5248d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.562 For version [AppleTV2 4.3 (4.2.2) (8F305)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.578 APPLE is NOT signing AppleTV2 4.3 (4.2.2) (8F305) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.687 For version [AppleTV2 4.3 (4.2) (8F191m)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.703 APPLE is NOT signing AppleTV2 4.3 (4.2) (8F191m) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.796 For version [AppleTV2 4.2.1 (4.1.1) (8C154)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.828 APPLE is NOT signing AppleTV2 4.2.1 (4.1.1) (8C154) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:16.921 For version [AppleTV2 4.3b2 (8F5153d)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:16.937 APPLE is NOT signing AppleTV2 4.3b2 (8F5153d) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:17.046 For version [AppleTV2 5.1 (9B179b)] - This device isn’t eligible for the requested build.
07/10/2012 23:06:17.062 APPLE is NOT signing AppleTV2 5.1 (9B179b) SHSH requests anymore. All you can do now is select CYDIA and hope that CYDIA has your SHSH saved. If not, there is nothing you can do.
07/10/2012 23:06:17.077 Finished saving SHSHs for [Apple TV]
07/10/2012 23:06:17.140 Caching shsh files…
07/10/2012 23:06:17.155 Found [0] shsh files to cache…
07/10/2012 23:06:17.171 Cached [0] shsh file
