Saving IPSW
I downloaded the latest version of Seas0npass with the intention of performing a tethered jailbreak for 4.4.2 (9A336a).  Everytime I save the file my computer saves it as a zip file.  I’ve tried extracting the files, but this still doesn’t help.  When I try to locate the file (shift + click) by clicking on “Create IPSW” Seas0npass won’t recognize the folder as an .ipsw file.
You just need to change the file extension from zip to ipsw.  I had the same issue using Windows 7.  If you are also using Windows 7 here is a link that should help you out.
http://www.programmerfish.com/how-to-change-file-extension-in-windows-7/
I tried that after extracting the files, but didn’t think to try renaming the zip file.  Thanks, it worked!
