Hello
Export DataMeta Plex Infuses as a file then im
I have a big Plex library
Infuse has been running for 8 days. It is searching and fetching data… very slow and annoying… Now I want to log in to another mobile or Apple TV
My suggestion: For example, exporting the library ready in the form of a file or calling it via a zip link, for example, or any other format
It fetches and searches for new data, not the entire library
Save information and data of the library in the form of a file from Infuse
Open another infuse with a new device and upload the library in a minute
opsops
2
You could sync over iCloud.
This should be resolved in upcoming direct mode feature:
We are waiting for the solution
You can follow the link provided by @munpip214 above to find out the status.
