I just upgraded to atv 3.3.5 running Apple TV v2.2 software. I can no longer find my Sapphire menu, plus when I try to access Boxee or or XBMC, I get an error message saying the required items can’t be found.
The upgrade appeared to go without and errors, Any help?
Sapphire has not been around since 3.3.2 since the developers of Sapphire have not come out with an AppleTV 2.2 compatible version. Just so you know, you can check the version notes of every aTV Flash version here: http://forum.atvflash.com/viewtopic.php?f=11&t=91
As far as XBMC and Boxee, even though the patch installs the launchr, you have to go into XBMC/Boxee > Update. Then update the Launcher, XBMC, and then Boxee. Once you run all the updates you will be able to run all the programs.
