Sapphire and Realplayer
Is there any way for Sapphire on an AppleTv to process Realplayer formats? I have and will continue to receive a large number of movies in these formats and don’t look forward to a metadata gap or a manual conversion of the files.
Cheers & thanks in advance.
Currently nitoTV is the only application that can play these files. You’ll just need to install the additional Mplayer codecs through the nitoTV --> Settings --> Install Software menu.
Thanks for the response. As you suggested, I am now able to view Realplayer files via the nitoTV->Files option.
Sapphire still does not recognize these files for metadata and direct access purposes. It sure would be nice.
