can you stream music and movies from the SanDisk Connect Wireless Stick to infuse app from itunes if so how do you do it thank you.
yes it works from infuse. You add wireless usb pen from Sandisk app then go infuse right hand corner add files and movies player.
BIG however if you have DTS or AC3 (most pirate movies do) then you’ll need the pro version, or you’ll get no sound.
