Hello
I’ve talked about this before as you can see and 7.2 has fixed most of the problems from then. Good Job!
However, there is one thing that I think should be fixed. If a show has a Swedish translation of the show description but not for individual episodes, you get the same show description on every episode. It would be better, I think, if we then could get the individual English description instead.
I tried something like this on TMDB with the tv-show Hacks. I had written a Swedish show description (SD) and an episode description(ED) for episode 1. For all the other episodes I of course then got the SD in Infuse. I then removed my Swedish SD from tmdb and got individual English ED on all episodes. It even removed my Swedish ED from episode 1 which is fine because it sucked but I wanted you to know that it did that in case you didn’t.
