S.W.A.T. (2017) is not properly recognized as a TV Serie by Infuse
I noticed that S.W.A.T. (2017) is not properly recognized as a TV Serie by Infuse.
I named the files as exactly shown on thetvdb: (https://www.thetvdb.com/?tab=series&id=328687)
-S.W.A.T. (2017)
–\Season 1
—S.W.A.T. (2017).S01E01.Pilot.mkv
—S.W.A.T. (2017).S01E02.Cuchillo.mkv
The seperate files appear in the Other section instead of under TV Shows.
I guess the dots in the filename may confuse Infuse, any idea how to fix this?
Rico.
Try it without the parentheses around the year. Like S.W.A.T.2017.s01e01.mkv. That worked for me.
Infuse doesn’t like series names that include dots or hyphens. We have a few ideas for improving this we hope to include in a future update.
For now, you can either remove the dots (IE SWAT instead of S.W.A.T.) or use the edit option in Infuse to search for for a title manually (correctly a single episode will automatically correct the rest of the season as well).
Thanks Bullseye & James for the suggestions. SWAT is now back in my TV Shows section. :wink:
