Hello– Seen some of the other posts regarding this problem in earlier versions, but not in 4.03. It is in NitoTV or Files (either one), if we try to rewind something the Finder crashes. Is there a work-around in 4.03 or something else to install?
Thanks! Corey
It sounds like the codecs may not have installed properly. You might try re-installing using the USB flash drive.
Downloaded the 4.05 stuff this morning and re-installed from the USB flash. Everything seems to be working correctly now. Thanks for the help! Corey
