Restore to another ATV
Hi. I bought a new ATV and would like to fully restore the infuse shares I have setup in the older ATV into it. Is this possible somehow? Thanks in advance.
If you have Infuse on the older one set up to sync to iCloud, then just set up the new one to also sync with iCloud and it will automatically set up the same shares on the new one.
What @remotevisitor said but also it has to be the same Apple user ID.
Thanks. Doesn’t seem to work though. iCloud sync is enabled by default and nothing happens. Using same Apple ID. Backup and restore also seems to be tied to the device so doesn’t work for this.
After you download the app to the new ATV you don’t need to enter anything, just launch Infuse and go to settings > Library and you should see messages on the left side with the icloud syncing etc. Just let it run and it should be good.
It says it’s syncing, stays there for some seconds, then stops, and on the right says sync with iCloud (last Today 20:39). But library remains empty unfortunately.
I just read that Plex is not supported in this case. Case closed, thanks.
