I’m trying to re-map to a Windows share, after having found it necessary to factory restore my ATV & reinstall ATVFlash.
Initially, I entered the network details, but made a mistake, and so deleted and started over. Now I’ve entered them correctly, but I get a ‘resource busy’ message when trying to connect.
I’ve had this error before (some time ago) and I think I recall having to SSH onto the box to fix it. Something about it ‘remembering’ the previous (incorrect) mapping. Unfortunately, I’ve forgotten the actual procedure (and where I found it!).
This sounds similar to a problem I had a little while back. I didn’t equate it with the ATV ‘remember’ the incorrect settings but you may have hit the nail on the head.
My solution was to a create an entirely new share on the Mac then setup a new mount on the ATV with one or two sample movies. Once that was all happy I then simply changed the settings of the mount to the original shared folder where my movies live, while keeping the mount name the same.
