Hello,
Do you think it will be possible to play 1080p or 4K files at their own resolution on infuse ?
Regardless of Apple TV resolution setting ( UHD for example to play netflix … in 4K) , if we play a 1080p on infuse, output will be 1080p ( upscaling will be done by 4K TV with clearness used to improove quality picture and not by the ATV) , if we play 4K file, output will be 4K resolution.
I ask that because on Shield TV using KODI we can do that and it will be great to have same thing with ATV 4K ![]()
regards
The Apple TV supports automatic matching for refresh rate and dynamic range only.
Unfortunately the resolution is not adjustable via the APIs provided by Apple.
Ok, thanks for the answer ![]()
