Resolution mismatch
I have started noticing recently that UHD/4k is sometimes not correctly recognised. It is being displayed as 1080p. The movie plays in UHD but metadata doesn’t reflect it. Wonder if anyone else has seen this thanks
It may be because the video has been cropped to a point that it falls out of the range that Infuse recognizes as a specific category.
You can see the ranges here Filter by video resolution - #7 by james
By chance were these videos replaced with higher resolution versions? If so, Infuse would retain the previously cached specs.
To refresh the specs, simply tap the Edit option and re-select the correct video title.
