Resetting infuse to factory settings
@james hello.
It would be convenient if, when returning to factory settings, infuse returned previously hidden tiles to the main screen. Such as TV shows and so on. Infuse is not doing this right now.
I support, this is a very good idea, a new user is faced with the problem of restoring default settings.
If you truly want to revert to a “factory” new infuse install you’ll have to also delete the iCloud data for it. You’ll first delete the app then delete the iCloud data and then reinstall the app.
So, of course you can do it. But, this is a lot of action and can confuse a beginner.
It would be easier and more convenient if infuse itself could do all this at the touch of a button.
I wonder if the developers can implement this or not.
That’s why I created this theme. An interesting opinion on this matter @james
