While the new On Deck support is a great addition, it would be great if we could have an option to replace the Recently Added section with the On Deck on the Apple TV.
Also (and this may be more important), the home screen integration should be configurable to have whatever list you want. It’s recently added right now which is useless unless you’re always completely up to date on shows.
Thanks!
