Hello, I was wondering if in the future versions of Seas0npass if you guys may be able to include root volume resizing for the atv2 on the various firmware ipsw’s. Currently, the sn0wbreeze v2.9.6 tool allows us to resize the root partition in atv2 fw 5.0.2, but sn0wbreeze does not have all of the files, tools, and tweaks that you guys have within seas0npass.
Please see http://imho.nu/iMHo/resize-root-partition/ for instructions. The basic idea is that we will go from this:
ATV:/ root# df -a -h
Filesystem Size Used Avail Use% Mounted on
/dev/disk0s1s1 681M 620M 55M 92% /
devfs 26K 26K 0 100% /dev
/dev/disk0s1s2 6.8G 441M 6.4G 7% /private/var
To this:
/dev/disk0s1s1 2.4G 626M 1.7G 27% /
/dev/disk0s1s2 5.2G 114M 5.0G 3% /private/var
I am testing it now, and it seems to work okay in terms of the basic jailbreak. We of course do not see the firecore logo on the settings, but ssh’ing into the device works.
Also comparing the output of “apt-get update”, the sn0wbreeze ipsw is missing a lot of the cydia sources that firecore contains.
So i guess i’ll keep playing with it and continue trying to mess around and make it work, but it would be really great if the seas0npass team would add this partition resize functionality to give us atv2 owners a little more space on the root partition.
Thank you!
