Rename Libary favourite
Would like to suggest the option to rename the Library favourite on the home screen so that I can blank out the text below the icon.
Currently it is possible to this do for all the other favourite shortcuts, but the Library does not provide this option. I use custom images for the favourites that already have the text in them so the text below each icon is unnecessary.
Alternatively a global option to remove the text from the home screen favourites would be preferred, as it would not then blank the names of the shares in the menu as it does now, plus could remove the problem of the blank space remaining under the favourite menu bar if the text is removed rather than hidden.
