Hello, I’ve just synced my Emby library, but I would like to rename it. However, I can’t find any way to do so. Is there any solution? I would prefer not to delete the library and resync it again. Thanks!
The actual Library name can be changed on the Emby server.
If you just want to change the name of the lists which appear on the home screen, you can tap the ‘Lists’ icon in the top right corner of the home screen and adjust the names there.
I forgot to mention that I’m testing the Mac app version and finally found where to change it. In the Library, the “+ Add” button now shows a pencil icon for each added library. Thanks!
