Hi, am i blind or is there not a function for Remove the viewed Movies in settings in infuse 5 pro ?
do you mean delete the files off the server? If so you need to have enabled File Management under the inFuse settings.
Nope, how to Remove viewed files from the last viewed screen in app or top view when selecting infuse
Anyone?
