Remove power cable
Hi guys,
Is it normal all times I remove power cable the Apple TV 2 lost settings?
Everytimes I have to re-jailbreak!!!
Thanks in advance for helping me!
With the 2.5.1 tethered jailbreak it is normal after you have removed power for you to have to repeat the tethered boot stage to complete the boot when you next power on.   You do not need to repeat the previous jailbreak stage which creates the .ipsw file and uses iTunes to restore it.   If you are repeating the iTunes restore each time it would explain why your settings are being lost.
Thanks for your suggestion?
If I understanding when the untethered boot will be available I’ll not have to continue to do that…
Do you know when it will be ready?
As far as I know there is no ETA for an untethered jailbreak of the 2.5.1 firmware, and not even a guarantee that one will appear.
The rumour I have heard is that the jailbreak community re holding back some exploits until Apple makes iOS7 available.   The reason is to try and avoid Apple patching the vulnerabilities before they can usefully be exploited.
