I installed couch pro surfer. What if I wanto to remove it? How should I proceed?
Thanks for the help… and sorry if this is not the correct place for this question.
It can be removed from the Maintenance menu in the same place from which you installed it.
Let me provide a slightly more helpful response. Go to the menu area where the install was done. Scroll to Couch Pro Surfer and hit the “Right” direction button. This will bring up the prompt to delete it.
This.
