Remote problem after installing USB drive support
I installed the USB hard drive support and now the remote doesn’t function.
The ATV sees it and respond with change of light when i press a button but no change in the menu
Any ideas?
Help
Did you restart the Apple TV after running through the smart installer?
I have the same issue and the exact same circumstances. I installed the USB drive support and now none of my IR remotes will function. I can navigate using the Remote iPhone app (of course only using the none aTV Flash features). Since the remote isn’t functioning, I don’t have any way to restore either…do I? Need help on this one quickly!
Dr. Steven B. Combs
:: Give Us One Minute (GUOM)
:: http://www.giveusoneminute.com
:: giveusoneminute@gmail.com
Found the solution for this one. Seems if you pair your remote with the AppleTV (as I had done), the USB drive patch disables the remote for some strange reason. To correct the problems, simply un-pair the remote from the AppleTV by pointing the remote at the AppleTV and then pressing and holding the menu button and the |<< button for a few seconds. The un-pairing icon will appear on the screen and all will be fixed.
Dr. Steven B. Combs
That did the trick for me. Thank you Doctor!
Thanks Steven. We weren’t aware of that.
Hi there,
did you get it to work in nito?
I´m still unable to
  1. select items in DVD sub menues (languages, subtitles etc)
  2. perform keymapping to switch subs etc during playback
    via the remote.
Gero
