Remote HD, how to
Can anybody Tell me how and what I have to install to use Remote hd?
So far I have the App. on my iPad Running. I have upgraded my ATV Flash. But my iPad Shows nothing, and I can Not find a menu where I can Select the Device to Control.
Can anybody help?
Thanx
S
Remote HD can be installed on the AppleTV through the Maintenance → Install Extras menu.
 I'm having a similar problem
Remote HD doesn't show up on menus anywhere
This includes the Maintenance --> Install Extras menu and the Maintenance --> Manage Plugins menu
How do I find/install Remote HD?
Which version of AppleTV software (Settings --> General --> About) do you have installed?  Remote HD is only available if you're running AppleTV 3.0 or later.
