Right now im using webdav as that was the only option that worked…Can SMB or NFS be used as everyone claims its better?? (im not that tech savvy)
For remote connections, WebDAV or FTP/SFTP are usually preferred.
Some people have had success with SMB, but the setup can be a bit more work and some ISPs block the ports required in order to stream via this method.
