Reinstall Adobe Flash?
Was just a tad quick when installing Flash before I read about the CoreAudioKit.framework…
I’ve found the file AFTER installing Flash (Maintenance / Install Extras - Now says “Installed”)
I would like to run it again since I know what the CoreAudioKit files available.
I’ve verified that Flash doesn’t work - although the status is installed.
Thanks!
/J
Just put the coreaudiokit in the documents folder, uninstall flash (by moving to it and clicking right arrow) and then reinstall it.
Excellent - Thanks!
/J
