I’m having trouble forcing Infuse to check the file information again. I have a higher quality file than previously, but Infuse continues to show the old mbps, codec, resolution etc. I’ve removed the file from the watched SMB folder and readded it, done a few metadata refreshes and ‘scan for changes’ but I can’t get it to update. Any ideas?
