tvOS has a feature called „reduce loud noises“. This is a great feature when you a watching action movies - this feature reduces loud noises like explosions etc.
The problem is, that I only use this feature when I watch movies and tv Shows in Infuse. I disable it when I listen to music, because with this setting on there is practically no bass.
So it would be nice if Infuse has an own setting for this.
I don’t use that feature and I don’t use Siri but have you by any chance tried telling Siri to “Reduce loud sounds”?
Might be a simple answer.
Yes just ask Siri or go into settings
