Recycle Bin
Is there any way to hide the recycle bin for a USB HDD? It shows up under the NitoTV Files menu when you browse to the drive. Thanks.
Is the drive used solely for the AppleTV? If so, you can remove the recycle bin folder through the AppleTV.
1. Enable file deletions through the nitoTV --> Settings --> General menu.
2. Delete the recycle bin item by highlighting it, and pressing the left arrow.
3. Disable the file deletion setting (optional, but recommended).
