Recycle.bin folder
Hello James, recently I discovered a little problem about infuse and the recycle.bin folder. After I deleted some files using the windows system from my library, Infuse was still displaying these deleted file. Infuse will look into the recycle.bin folder and displays the files and it will also play these files like normal.
The files will appear in a different name :
For a file name ; video123.mkv it will display $12zv23uvt.mkv.
And all files name will look something like that.
Is there a way to stop infuse from looking into the recycle.bin folder
Thank you
A post was merged into an existing topic: Filter $RECYCLE.BIN Folders
