Recommended settings for Panasonic OLED TV 2018
Hello there
I’m not sure if I am the only one but I use a Panasonic OLED TV from 2018 (TH-55FZ950S). I was wondering if anyone would like to share the settings from the TV and from the Apple TV 4K.
Thanks in advance.
I can’t comment on TV settings since we haven’t tested this model, but as far as the Apple TV goes, we recommend enabling the Match Content options as described here. About frame rate and dynamic range matching on Apple TV - Apple Support
This will ensure the Apple TV adjusts its settings to match the video you are currently playing for the best possible picture.
Check rtings website for settings.
Thanks for your messages, I’ve activated the settings in the Apple TV.
I think rtings doesn’t have my TV because it’s not sold in America.
I’ll ask in another forum.
I believe they use an LG panel… much like Sony. By comparing the two you should be able to get an idea on what to use.
Hi! I believe Flatpanels HD review Panasonic OLEDs and they have settings there as well!
