Rebuild tunnelblick
Hi ATVFlash,
There are a lot of people including myself that have a VPN provider at require username password and there can’t Tunnelblick on appletv. This could easilly be solved by rebuilding tunnelblick with the option --enable-password-save. This way a text file can be included with the username and password and the text files reference added to the conf file.
Username/password authentication is now supported.
http://forum.atvflash.com/viewtopic.php?f=6&t=2504&start=40#p10802
