Yesterday I installed aTV Flash V3.4.2. Reading the caution about installing advanced plugins, I did not install the “Disable auto update” plugin. How do I now go back and install the Disable Auto plugin :?:
Thanks again, Flicker
Under Maintenance you should see an option to Disable ATV Update and won’t have to reinstall the patch. If you don’t have the Maintenance screen then you will have to recreate aTV Flash and check the box.
