Re-analyze Video Technical Metadata
When video files are replaced on my Google Drive directly, the technical metadata parts are t updated in Infuse. So I end up having a movie showing it is 1080p but I deleted that file and added a 2160p version of it.
Currently the only way to avoid this, as far as I know, is to add the new video file, have Infuse index & then delete the unwanted version from within Infuse. This method is inconveniently slow.
I’d want a way to re-analyze the audio & video metadata info just like we have with the matching of the movie to the correct posters and descriptions and such.
If you do an “Edit Metadata” and re-select the correct choice Infuse will update the tech data. Is that what you’re wanting to do?
oh, I wish I had known that a long time ago. Thank you @NC_Bullseye
