Trying to watch Gangs of London. But image is very bad. Took some shots from infuse and my oppo playing back the same file. Obvious difference. It does so with all versions down to 4.1. Can’t go back any further. Release used
Gangs.Of.London.S01E01.INTERNAL.1080p.AHDTV.x264-FaiLED
Also the akira uhd bluray will not play without a loading every few seconds. Plays fine on oppo.
Just the clarify you are playing the same 1080 file on both oppo and infuse and having issues and not the UHD. Did you make the HD copy yourself? Did you try having ATV plugged in to same HDMI port on the TV? There could be some settings there that are different too.
Oppo plays the exact same file as Infuse. Both are routed through an av receiver. Receiver video scaling turned off. Only difference is appletv output 4k resolution and oppo outputs 1080p on the Gangs of London file. 4K on akira uhd bluray.
So output should be the same. TV is calibrated as well.
