Over lightening charging cable or Ethernet cable ?
Also if I add the files over the lightening charging cable can I organize them into folder from within itunes or must I do that after?
The fastest transfer option will probably be via a USB cable via iTunes File Sharing.
Using the browser upload option via an Ethernet adapter could also be pretty fast.
I believe you can transfer a folder of videos via either option. If you transfer individual videos you can reorganize them in the Infuse app by following these steps.
