Copy the CoreAudioKit.framework to the Apple TV, to the default (home) folder
I am trying to enable flash and need to know what the default (home) folder is on the apple tv when you access it via cyberduck or fugu.
I have also extracted the coreaudiokit.framework from my disk tiger discs and need to know if i should see a ‘success’ message or anything of that nature after i type in terminal----
sudo chown root:wheel /System/Library/Frameworks/CoreAudioKit.framework
