Question about updating to V6 PRO
Hello guys,
I purchased Infuse Pro 5(standalone) half year ago. Can I updating to V6 Pro for free?
I have gone through all relevant information here but still…confusing…
Thx
If you purchased the stand alone Infuse 5 Pro then you’ll either need to purchase the standalone of Infuse 6 Pro or get the Infuse 6 with in app purchases and start a subscription to 6 pro as far as I know.
Infuse 6 is a free upgrade for all Pro subscribers (monthly, yearly, lifetime).
If you have the standalone Pro app, there are discounted options available.
More info on these can be found near the end of this post.
I currently have Infuse Pro 5 standalone and in order to get Infuse 6 ORO lifetime, plan on installing Infuse 5 and in-app purchase a PRO lifetime subscription. Once this is done and Infuse is updated to version 6, how do I remove the original Infuse Pro 5 standalone from my devices ?
In my planning, I did not see any way of removing it so far.
Once you’ve got Infuse 6 up and running the way you like it, the Infuse Pro 5 app can be removed.
More info on deleting apps from Apple TV can be found here.
Thank you James. That’s the piece of info I was missing.
